- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Unknown new 'satellite' shown
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
I have the RBK853 WiFi 6 Mesh which has the 2 satellite, RBS850. Usually when I look at attached devices in the Orbi software I see the 2 RBS850 under the 'Connected Satellites' section and then a whole list of devices under the 'Connected Devices' section.
Today under the 'Connected Satellites' section there appears to be a 3rd satellite which is shown as 'XEROX CORPORATION' in the device name. Backhaul status is shown as 'Disconnected' and there is a button given to remove it.
I do not, and never have had, a third satellite. It isn't my printer which is not Xerox and is shown in the 'Connected Devices' section where it should be anyway.
Does anybody know why this could be showing as a satellite?
Firmware v4.6.14.3_2.3.12
Windows 10
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Other posters historically have posted about the same issue, FR was the permanent resolution.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Unknown new 'satellite' shown
Factory reset the RBR and RBS and setup from scratch.
Be sure FW is same on all RBS as what's loaded on the RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for replying.
Can you tell me why that is the solution? Is it not ok to just delete the extra 'satellite'?
- Mark as New
- Bookmark
- Subscribe
- Permalink
