- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Upgrade from RBK52 to RBK852: Many more "no signal"/connectivity issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is a continuation of discussion started on "AC3000 mesh wifi system (rbk50) vs ax6000 wifi mesh system (rbk852)".
Here is my initial post on 2021-01-29 09:11 PM:
"I just upgraded my RBK52 to an RBK852. Everything was the same. Same location for the satellite and the router. Both the 52 and 852 are in AP mode. My router is a Verizon G1100. I upgraded because I have 20 - 30 wifi devices depending on time of day and which devices are running (washer/dryer/Generac). I live in a townhouse community. The wifi is crowded. I have 10 wifi security cameras. Some are dual band; some are single 2.4 Ghz bands. Three cams are inside so only are running from dawn to dusk. I was attracted to the RBK852 since it could handle upwards of 60 to 100 wifi devices. It was based on wifi 6 chip set, with must more throughput and more antennas.
The RBK52 worked well most times. Occasionally, some cameras would drop (no signal) and I attributed that to increased wifi activity in my neighborhood. I decided to purchase the RBK852 to set up for the future with wifi 6 cams and other devices. The install went well. Since I already had the RBK52 in place I just needed to set up the RBK852 the same way, including the SSID/PW. Since the change I have a huge increase in the number of camera drops. I need to do more research as to why this is happening. I am surprised this is happening. The new satellite is the source of most of the drops. (Note: a drop to me is a loss of signal/connection. The connection is reestablished quickly, but the loss is noticeable. All my cams record 24/7 on Blueiris and they FTP to send pics when motion triggers an alarm. The RBK52 handled this. The RBK852 struggles with certain cameras. None of the cams have moved. I did not expect this. I am running the latest firmware (V3.2.16.22_1.4.9). More research from me."
Since then I have received many suggestions from @FURRYe38 , @vajim , @Mstrbig
I will update everyone as to where I am right now based on the suggestions so far:
Notes/Status:
1. The RBK52 has been running smoothly for nearly 3 years now.
2. I live in an end unit of a 3 unit townhouse. It is two stories with about 2100 original sq ft and an additional 176 sq ft sunroom addition. The house is on a slab, no basement/crawl space. There is a lot of wifi activity among all the units. I use NetSurveyor to monitor the various channels across both wifi bands.
3. The RBK52 router was positioned second floor front of building. The satellite was stationed in the sunroom, first floor. The distance between then (not accounting for the angle first floor to second) is approximately 40 feet.
4. I decided to upgrade to the RBK852 because I have any wifi devices and I get some "No signals". These I attributed (with no real science) to the heavy wifi in the neighborhood. Based on the RBK852 specs, it can handle 60 - 100 devices.
5. The intention was to set up the RBK852 just like the RBK52. Both are "AP Mode". The Verizon router G1100 has both wifi bands tuned off. It is acting as the router. My internet plan is 100/100. I have no issues with speed. I would change the setup to RBKs do the routing and set the G1100 to bridge mode, but I would lose many Verizon TV functions like the guide, etc.
6. I set up the RBK852 as close to the RBK52 as possible. There were a couple options that were different. I don't remember which ones.
7. On Wednesday, 2021-01-27, I switched the units. The RBK852 came up no issues and I was off an running. Over time though I noticed a huge uptick in my "no signals" on some security cams. By Friday I decided to switch back to the RBK52. See pic 2021-01-29.
8. Picture 2021-02-01 was from today. Not exactly the same number of hours butt it will give you a clear idea of the huge difference between the 2 systems. The RBK852 pic is after about 48 hours and the RBK52 after about 36 hours. Again, the systems are nearly identical in setup and location.
9. The four cams are the four most important to me. Two are in the front of the house (BFEast/JTWest) and two are in the rear (JTSouth/FCBack). The other cams are supporting and provide other views. All four are single band 2.4 GHz and are outside.
BFEast: 0 RBK52, 275 RBK852. JTWest: 9/90. JTSouth: 0/222. FCBack: 0/152. Pretty wide discrepancy.
10. All total I have 13 cams. Four are wired and don't count here. Nine are wifi.
11. Here is a list of most of my wifi devices. Not all are active all the time. 2 Nest thermostats, 1 Ring doorbell, 1 washer, 1 dryer, 1 Generac, 6 exterior cams, 3 interior cams, 2 iPhone 11s, I iPad mini, 4 laptops, 1 Roku and 1 robot vacuum.
12. There is no issue with internet speed up and down. The backhaul of the RBK852 is faster than RBK52.
Bottom line, the issue is the number of "no signals" or loss of connectivity with these cams.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Upgrade from RBK52 to RBK852: Many more "no signal"/connectivity issues
Here is the RBK852 stats pic.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here is the RBK52 picture.
Note: The stats are take via BlueIris. I use this software as my video recorder (NVR). All cameras run under BI. They record 24/7 except for 5 in-house cams that only record dawn to dusk. No issues with bandwidth with the RBK52.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried disabling AX Mode?
What are your CTS Values? Try 2347 Under Advanced Tab/Advanced Settings/Wireless Settings
What are you channel settings? Same as what you had on the RBK50 series system?
What is the distance between the RBR/RBS and these cameras?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 I'm still on the RBK52. I'm switching back to the RBK853 tomorrow to check out these suggestions.
What I can tell you is that the distance between the cams and the R&S is the same for both systems.
I will try turning off the ax mode, although that's why I purchased the system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry for not getting back sooner. I tried the suggestions above. Nothing seemed to work better. The old RBK52 performed better every time. I could only leave the RBK852 up for a couple of hours as several my cameras kept losing signals/dropped. A lot of drops. Switching back to the RBK52 only took a few minutes as it was a simple swap in place. All else (settings, etc) were the same.
I am disappointed in that I wanted the RBK852 becasue it would handle 60 - 100 devices. I am at around 30 right now. Many of my cams are running at 1080p/10 fps. That's about all the RBK52 can handle. I was looking forward to upgrading to the RBK852 so I could run my cams at 4MP/5MP at 20 fps and add more wifi devices.
After all the effort I decided to return the RBK852. Now I don't know what to do....
Many thanks for everyone's assistance. I appreciate it very much!
JRS
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried turning down the radio power? I know it seems counterintuitive, but that is worth a shot to reduce it and see if you are creating electromagnetic interference by having more powerful radios.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@JohnyBeGood wrote:I am disappointed in that I wanted the RBK852 becasue it would handle 60 - 100 devices. I am at around 30 right now. Many of my cams are running at 1080p/10 fps. That's about all the RBK52 can handle. I was looking forward to upgrading to the RBK852 so I could run my cams at 4MP/5MP at 20 fps and add more wifi devices.
You've already returned it but for anyone else reading this thread -- This sounds like a wireless connection issue with the OP's cameras and not a capacity one. My RBR850 + 1 satellite has 60 connected devices, including 11 Nest cameras transmitting 24/7 along with 7 Arlo cameras.
Wireless connectivity issues can usually be solved via Orbi's advanced wireless settings. It's unfortunate, but Orbi AX and its default settings can unfortunately be finnicky with older wireless clients. I found that setting CTS/RTS threshold to 2347 solved my older 2.4Ghz wireless connectivity problems. I also disabled AX mode for 2.4Ghz but left it on for 5Ghz (since my newer AX devices like iPhone connect ast 5Ghz).
