Orbi WiFi 7 RBE973
Reply
Very Expensive Orbi Rout RBR850 - several devices failing to connect
egasxam
Follower
Had this product for about 18 months. Now finding devices failing to connect to the wifi on a regular basis. Unfortunately the paltry 90 days support has now expired - atrocious support from Netgear! Why if your products are worth the heafty price tag dont you offer longer support . Router rebooted several times. Firmware up to date. All Satellites well within specified range. Any advice would be welcome.
Message 1 of 4
Guru
Re: Very Expensive Orbi Rout RBR850 - several devices failing to connect
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What devices do you have all connected?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 4
ekhalil
Master
Orbi will work very well if configurded correctly and if the network to which it's connected is healthy.
  1. Please make sure that you don't have multiple routing (multiple NAT). Please check that the ISP modem is not functioning as a router if Orbi is operating in router mode.
  2. Please make sure no device in your network is causing IP loops. Devices that have both active Ethernet and Wifi interfaces is an example. Also mesh wifi speakers can cause such issues.
  3. Please make sure that no other device in the network is acting as a DHCP server apart from the main router.
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBR850 + RBS850 + 2x RBS750 + 3xRBS350, Wired/Wireless BH / Orbi RBR50 + 6x RBS50 + RBS40V + RBS50Y, Wired/Wireless BH | Switches NG GS208Time Zone CET (Sweden)
Message 3 of 4
CrimpOn
Guru
Would be helpful to know what sort of devices are failing to connect.
  • Did these devices connect correctly in the past?
  • What is the indication that devices are not connecting?
    • An error message on the device?
    • No longer appearing on smartphone applications?
I love my Orbi.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 319 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
