- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
What can be used as a wireless Hub/switch?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just upgraded my RBR50 with an RBR850, and I upgraded my RBS40/RBS50 units with RBS750s. However, I have one question that I wondered if anyone has any insights into:
My son's room doesn't have a wired connection, and his room is about 20 feet from the office (and the RBK850), on the same level. So, basically, a couple of walls between the RBS750 we are using as a connection point for his computer and the main router.
My concern is that the RBS750 and the RBR850, being so close together might be causing RF interference with each other. Basically I am wondering if there is a device that will allow for a passive WIFI6 connection that would allow me to connect either a regular hub, or would act as a wireless hub so I don't have to have an RBS750 in his room??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: What can be used as a wireless Hub/switch?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
You should be able to have the RBS in his room. IF it's kind of close to the RBR in the office, tryturning down the power output of the RBRs wifi radios from 100% to 25% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
You could try power line adapters:
https://www.netgear.com/home/wired/powerline/
However you'd still need to turn down the power on the RBR if still having the RBS kind of close to the RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mgpaulus wrote:My son's room doesn't have a wired connection, and his room is about 20 feet from the office (and the RBK850), on the same level. So, basically, a couple of walls between the RBS750 we are using as a connection point for his computer and the main router.
I don't think this should be of concern. You don't need more satellites within 20 ft of each other, even with walls in between, and the wireless connected Orbi satellites work just fine. If your son is not having Internet connectivity problems from his room then don't worry about it.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
