Orbi WiFi 7 RBE973
Reply
Where is the source code of acos_nat.ko (a GPL'd kernel module used in RBR750)
gb777
Apprentice
Does anyone know where to find the source code for acos_nat.ko (distributed as part of the RBR750 firmware?)
This Linux kernel module contains a .modinfo section that lists its license as "GPL".  It also calls ip_route_output_flow which is marked EXPORT_SYMBOL_GPL in the Linux 4.4.60 kernel.
Therefore, it must be distributed under the GPL - but I haven't been able to locate it in the tarball available from the NG website. Does anyboy happen to have information where the source code of this kernel module is located?
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 495 views
  • 2 kudos
  • 1 in conversation
Announcements
Orbi 770 Series
