- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wired connection a fraction of Wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Model is the AX6000 RBK853 (I could not find it in the options above)
https://www.netgear.com/orbi/rbk853.aspx
Hey guys
I just received my brand new Orbi mesh system and I am extremely excited about it. I have a 1Gb speed at home and I can see my wifi speed is closer to 600M with the latest Intel Wireless cards I installed on my laptops. My question is regarding the wired connection from both of my satellites. I was expecting to get closer to 1GB from the satellites, yet I am only getting around 250M.
Why is this? What can I do to troubleshoot this? I actually purchased this system in hopes of having 1GB all across my house both wifi and wired.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wired connection a fraction of Wifi
I
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Try setting CTS to 2347. Save settings and reboot the router and satellite(s).
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. Let me try to answer all the questions I currently have an answer to
The very last one. I installed this system on Tuesday and it immediatley asked me to update to the latest firmware. V3.2.16.22
Netgear CM1000
2252sq ft.
The distance between the router and one of the satellites is not even 15 ft. This is because my internet cable comes directly to my TV room yet some of my computers are in an adjacent room. One of the reasons I purchased this system was to have ultra fast wired connection in this room. What i am finding though is that the wired speed coming from the satellites is not what I was expecting.
Where can I change the channels? I have clicked everywhere on the app and I cannot find that setting?
Yes there are neighbors, I can see a multitude of wifi networks on my mobile phone
Where/how can I do all this?
If you mean "Armor" the security feature that comes with the app. I did disable that and my wired speed increased by about 30Mb but it was not considerable. Again, my issue is with the wired speed coming out of my satellites (both of them). If I connect directly to the router I do get my 1GB of speed.
Please help me by indicating where cna I go to change the channels and all the other settings you recommended.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks
What size network cable are you using to connect your PC to the router? Should be Cat5e or bigger. If it is a Cat5 cable, you will lose wired connection speed.
