donawalt's avatar
donawalt
Hero - Experienced User
Apr 25, 2024
YIKES!!! 5GHz Wireless speed has dropped 90%!
I won't bore you all with the discovery and investigation details, but I am seeing WiFi speed on the 5GHz channel, right next to the the RBS960s AND RBR960, of about 15Mbps-50Mbps on a 2GB/200MB Comcast service! This started all of a sudden last night, with nothing being done to the network prior.
- No settings have changed in at least 2-3 days, probably more;
- This happens to multiple devices, iPads, iPhones, Macs
- 6GHz works fine. I can take my iPhone, put it next to any RBR/RBS, and run a speedtest at 6GHz - I get 1400 Mbps. I turn off WiFi 6 on the device, pushing it to 5GHz, and I get 15-50Mbps;
- Direct Wired Ethernet devices (to the 2.5GHz multi-gig switch) are still working fine with proper speeds.
- After trying many troubleshooting ideas without success, I ultimately powered down the entire network in sequence, including the modem - I powered up just the modem and router, and the same thing happens at 5Ghz!
There's no way 5GHz could have been turned off or greatly minimized any way, is there? the 5GHz AX setting is still enabled.
My configuration:
-NG CM3000 modem -> NG Orbi RBR960 router -> NG XS508M multi-gig switch -> two RBS960 satellites (ie Ethernet backhaul)
- There is also a NG GS348 Gigabit switch connected to the router, which has lower speed devices and unused room outlets on it.
Help! What can I try?
  • plemans's avatar
    Does it matter if its connected to the router or the satellites?
    I know its a scorched earth attempt but did you try the old "factory reset" option?
    • donawalt's avatar
      donawalt
      Hi plemans no, it doesn't matter - it can be connected to the router or either satellite, and the very low 5GHz speed tests are the same.
      I suspect I may have to do the whole factory reset and build from scratch. Bad time in my week for this to happen ☹️  But wow is it PAINFULLY slow...we have gotten used to these faster Gigabit+ wifi speeds haven't we?
      • plemans's avatar
        For sure! I remember a couple months ago getting bumped up from the 40mbps upload to 240mbps on xfinity and its been a remarkable difference in performance. Made me realize how nice the fibre people had it.
  • FURRYe38's avatar
    Was this happening before you changed to the new LAN switches?
    My configuration:
    • donawalt's avatar
      donawalt
      @plemans - re: did you try the old "change the 5ghz channel"?  - good idea I'll try that!
      FURRYe38 - no, never saw this in my life on a home network before last night!
      • donawalt's avatar
        donawalt
        plemans I changed it from 48 to 44 - waited to see it update on my WiFi analyzer app - and tested it, No change in performance. I took this snapshot from the signal analyzer, as you can see (highlighted line) it believes it's a strong signal on 5 GHz with up to 2402 Mbps bandwidth. This is so odd.
