bbburson's avatar
bbburson
Follower
Dec 23, 2023
bbburson
NETGEAR - Orbi 960 Series.
The Wireless Wi-Fi IoT (2.4 GHz) stop working every 6-8 days. The other two channel 5 & 6 GHz have no issues.
So I have to reboot the system every 6-8 days.
(All the appliance, smart home devices, & etc. stop working, until I reboot.
1 Reply
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    How many RBS are deployed?
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    How many devices do you have connected to the IoT Netowrk? Same for main SSID network?
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
