Orbi WiFi 7 RBE973
Reply
can the orbi router rbr750 work as a satelite in a setup?
jepper35
Follower
i have to
Orbi RBK752 AX4200 tri-band mesh wi-fi 6 set and i wonder i i can use one of the routers as a satelite so i get 1 router and 3 satelite?
Message 1 of 9
Guru
Re: can the orbi router rbr750 work as a satelite in a setup?
RBRs can only work in router or AP mode. Not as RBS.
Message 2 of 9
Foden
Apprentice
Aren't the satelite's basically AP's?
Message 3 of 9
CrimpOn
Guru
Yes, they are.  (Isn't a taxi cab basically a 'car'?)
The difference is that the all mesh systems communicate with each other about which devices are connected and have advanced features to handle the "hand off' from one access point to another.
A normal WiFi access point knows nothing about any other WiFi unit.
It is really irritating that Netgear decided to implement the Orbi system this way.  Other vendors who use identical hardware for routers and satellites allow the user to define which unit will be the gateway to the internet and the rest can be satellites.  But, Netgear chose to do it this way.
There was one enterprising hacker who discovered a way to change the original RBR50 router into an RBS50 satellite, but thus far no one has come up with a similar method for other models.
Message 4 of 9
Foden
Apprentice
And one guy/gal (Voxel) wrote his own custm firmware for their Orbi, but not ours. https://www.snbforums.com/threads/custom-firmware-build-for-orbi-rbk50-rbk53-rbr50-rbs50-v-9-2-5-2-1...
I noticed on the debug info you can get from (routerip)/debug.htm that the Orbi's are based off OpenWrt
Message 5 of 9
Guru
Message 6 of 9
Foden
Apprentice
I did say it was not for ours (by implication the RBR750 as that's the chat this was posted in)
Message 7 of 9
CrimpOn
Guru
In theory, anyone could take the GPL source code from Netgear's web site, recreate the package, and make any changes they want.  I tried and failed miserably.  I know of one other person who was successful.  Voxel is in a league of his own.
Message 8 of 9
Foden
Apprentice
Yesah, not something in my wheel house at all
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 3018 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
