leenin
Oct 03, 2020Follower
cbr40 satellites work with cbr750
I am extraordinarily angry. Turns out the thousands of dollars that I spent for a CBR40 and four satellites will not handle a gig speed.
If I buy a CBR750 will the satellites will the CBR40 satellites work with it?
thanks
1 Reply
No 5Ghz AC class wifi router or wifi device will ever see anything near 900Mpbs. They max out at around 400-500Mpbs actual download speeds depending upon mfrs design and support of the hardware.
Only WiFi AX can handle near 900mpbs on wifi.
