- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
help..RBR750 lost connection to satellites
- Mark as New
- Bookmark
- Subscribe
- Permalink
oh please help me..somebody with a brain that is working better then mine right now LOL. I am SO frustrated with this system right now. Last night, the connection between one satellite (That happens to have my tivo ) lost connection.
1. I pulled the power plug to reboot the satellite.. Still no connection. I thought I would be tricky so I switched out a second satellite (I have 4) rebooted and plugged in my Ethernet cable from the tivo. Still no connection.
2. I rebooted my Orbi Router. Still no connection.
3. I unplugged my modem, my netgear nighthawk and my Orbi. waited..plugged..Modem then nighthawk then Orbi.Is coonected to the nighthawk which is connected to my modem. Still nothing.
4. I re synced several times still no satellites found.
% Frustrates as hell I pulled the plug on everything and pressed the reset button on the orbi router and satellites.
5. Using the app I proceeded to setup everything but the app only finds the router still.
6. I have tried everything I can think of.
My netgear nighthawk is flashed so that is why my obi is connected to it instead of the second ethernet port on my arris modem.
HELP??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: help..RBR750 lost connection to satellites
Might need to factory reset the RBR and RBS and setup from scratch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for reaching out to me. I am at my wits end. Why does everything run smooth;y for months and then ..bam..
Firmware v4.6.5.14
My internet provider is comcast/xfinity and I am using my own modem/ Arris surfboard T25
Connected by cable/coax
I have tried a factory reset and the router is discovered but none of the satellites.
At least I pressed the factory reset button on all of the devices. Thank you for your help. I really appreciate it.
Rachele
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oh..I also am trying to hook up without using my flashed netgear nighthawk router but still only the router shows up. grrrrrrr
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the RBR is setup, bring one of the RBS to same room as the RBR.
Use the RBRs web page to add a RBS using a web broswer. Follow the instruction on the RBRs web page for adding a satellite...
See if the RBS can be added here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Yup..Tried that and it starts to add going as far as resyncing but then it fails. I am so lost here. You are so nice helping me out.
Thanks again
Rachele
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wondering if your RBS are at v.2 FW while the RBR was downgraded to v.14...This would cause this issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I wouldn't be able to check that out I dont think as I ca not get any read on the satellites.
The saga continues... Christine is helping me out too..
- Mark as New
- Bookmark
- Subscribe
- Permalink
Keep in contact. I've asked about users getting v2 back on there RBRs in cases where the RBR was downgraded and the RBS were not. If v.2 was updated on the RBR, I presume the RBS will probably reconnect correctly.
