- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
new RBRE950/RBSE950 firmware v6.3.7.10 issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
After upgrading I am unable to see the wired devices that are connected to the satellites. WiFi and router devices show fine in the list.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: new RBRE950/RBSE950 firmware v6.3.7.10 issues
If you log into the satellites through the browser, do they show up?
- Mark as New
- Bookmark
- Subscribe
- Permalink
For one of the satellites I don't see any of the wired devices
For the second one. I see only one device out of 3 with ip showing as 'unknown' (see image below)
I haven't resorted to factory reset yet
- Mark as New
- Bookmark
- Subscribe
- Permalink
It seems like it is an issue with the 6.3.7.10 satellite firmware.
I downgraded the version on my satellite (back to x.x.x.5) and the devices started to show properly.
I than did the same with the other satellite and it worked as well.
I than upgraded back one of hte satellites (x.x.x.10) and the issue showed up again. Downgrading back solved the issue.
I kept the router version as x.x.x.10 for now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
After the firmware update, did you try a factory reset of the satellite/routers?
If there's issues after a firmware change, its worth trying to see if an old setting is causing it.
If that doesn't help, then its probably a bug/issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good point @plemans. I forgot to mention that when I changed firmware I also have done factory reset on the satellites. I also have done factory reset on the router (all 3) in the initial state when things didn't work. But the fact it was 100% repro on the new firmware version and on both satellites does suggest there is an issue with the new firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I didn't see the same issue on my firmware so hopefully its just to few cases.
I know the mods/engineers watch the flagship forums a little closer than the standard device forums so hopefully its being tracked
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes. But mine are setup with a wired backhaul as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the info. Don't think that the backhaul matter in this case as you can see it when connecting to the satellite but everything is possible.
I found another weird thing (in the older firmware x.x.x.5) - after factory reset and before setting up my ssid, I gave it temporary password. connecting to the satellite showed all the wired devices but also showed a wifi device. Don't know what it is and not sure how it even connected (if at all) as it's not my ssid and the password was something I didn't use.
but that's a problem for another day 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
