Orbi WiFi 7 RBE973
Reply
orbi rbk853 + WAX610Y
frado007
Tutor
I wish to supplement my ORBI WIFI6 (RBK853) system with an outdoor wifi 6 extender for the garden. It seems that the only model offered by Netgear compatible with Orbi is the RBS50Y satellite, but it is wifi 5 and therefore does not meet my expectations. I am therefore considering acquiring the WAX610Y which is wifi 6, but I will lose the mesh effect and will have to set up a new network for the garden. The question is: Does the Orbi RBK853 router provide the PoE required to power the WAX610Y? (I couldn't find an answer in Orbi's technical specifications). Thank you.
Message 1 of 6
Accepted Solutions
CrimpOn
Guru
Re: orbi rbk853 + WAX610Y
Search Amazon for "PoE+ Ethernet surge protector". ($18.99US on Amazon) and pair it with an ordinary "PoE Injector" (under $20US on Amazon).
I did not find a combination PoE injector + surge protector device on Amazon.
It is interesting that Netgear specifically mentions the surge protector in the installation instructions for the WAX610Y
https://www.downloads.netgear.com/files/GDC/WAX610Y/WAX610Y_IG_EN.pdf
I have mounted several PoE powered security cameras outside and do not recall seeing a similar warning on the cameras.
Message 6 of 6
All Replies
Guru
No.
Message 2 of 6
frado007
Tutor
Thank you for your answer. Does it mean that rbk853 does not provide PoE ?
Message 3 of 6
CrimpOn
Guru
That is correct.  you will need an external PoE adapter (with ground).
Message 4 of 6
frado007
Tutor
ok can you please guide to a model that would be compliant with RBK853 + WAX610Y ? Thank you
Message 5 of 6
CrimpOn
Guru
Message 6 of 6
Discussion stats
  • 5 replies
  • 1245 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
