Orbi WiFi 7 RBE973
Reply
orbi rbr 760 wont connect to modem
Gchacha
Follower
My orbi rbr 760 was working and then the light on the router turned pink and wont connect to the modem
I am not a techy so I am at a loss at how to reconnect the orbi router to the modem.  I have had to change all devices directly to the modem, netgear C6900
Message 1 of 2
Guru
Re: orbi rbr 760 wont connect to modem
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. https://kb.netgear.com/27191/How-to-set-the-cable-modem-router-to-be-on-modem-only
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS8...
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 569 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
