Orbi WiFi 7 RBE973
Reply
rbr850, stopped broadcasting its SSID
Jroach
Luminary
I have an ORBI RBR850 that stopped broadcasting this AM.
I was able to get internet when directly attached to the modem but nothing through Orbi (wireless).  I didn't try a device wired to Orbi so not certain if this was a wireless only issue.  Anybody else had this issue before?
Message 1 of 6
Guru
Re: rbr850, stopped broadcasting its SSID
Try powering OFF the RBR for 30 seconds then back ON? Does it return then?
Message 2 of 6
Jroach
Luminary
Furrye38,
Thanks (again:).
I had already POR before posting but wanted to see if others have had a similar issue.  I only have about 30 days left before I can't return it and concerned of runing into an issue like my RBR50 had (the buggy firmware problem)
If it happens again I'll test the LAN connected devices to see if this is isolated to just wireless.
Can you think of other things to test?
Message 3 of 6
Guru
Try a full factory reset and setup from scratch.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Message 4 of 6
Jroach
Luminary
Thanks Furrye38 but I want avoid reset for the sake of getting it running.
Per support:  I changed the MTU to 1408, changed the cahnnel on 2.4Ghz to 6 (from auto), left the 5Ghz at 48.  All wireless devices stopped working even when in the same room as the router.  Laptops kept search for SSID but couldn't find it.  Tried access Orbi's interface without success.  I will try the wired devices next time I have the problem but my support runs out soon and my ability to return to BestBuys is running out.
Message 5 of 6
Guru
As last resort I'd do the factory reset.
And you may have a faulty system which would need to be replaced.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 988 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
