CORDEL's avatar
CORDEL
Follower
Apr 03, 2020
2.4Ghz setting
Can the satellite operate at 2.4 GHz? In the app is is set to 5 Ghz
  • All Orbi's (router and satellites) broadcast (to user devices) on both 2.4G and 5G channels.
    The "backhaul" connection between router and satellites is a separate 5G channel that is chosen to avoid interfering with the user connections.  Satellites will "fall back" to a 2.4G backhaul if the 5G backhaul signal falls off too much.
1 Reply
  • CrimpOn's avatar
    CrimpOn
