- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC2200 Mini Orbi Router (RBR40) can not connect Laptops
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am new to this Forum and I am sorry if this issue has been addressed before.
Today I installed an ORBI WI-FI Router RBR40 AC2200. Installation went perfect and I was able to connect iPhones, iPads, FireTV, Directv, Rachio controller. When I attempted to connect Laptops, neither mine nor my wife's would connect. I keep getting Can not connect to this Network. It does not even give me a window to type in Password for Network.
Both PCs are ASUS Windows 10. I have run diagnostics to no avail.
please point me in the right direction.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad it was a simple fix. Please mark your thread as solved so others will know.
Enjoy.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC2200 Mini Orbi Router (RBR40) can not connect Laptops
@NJ1305 wrote:Both PCs are ASUS Windows 10. I have run diagnostics to no avail.
How strange. My Windows 10 laptop connects to my Orbi. So, you see the list of available WiFi access points. The Orbi is one of them. You click on the Orbi SSID, and the laptop immediately displays the "Cannot connect" message?
What happens if you activate the Guest WiFi? Will the laptops connect to it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What security mode are you using? WPA2 and AES should be set first.
Try using a simple password for the SSID security.
You can temporarily disable wifi security on the RBR and see if these two devices connect, if they do, then go back and re-enabled WPA2 and AES.
Make sure all wifi adapter drivers are updated.
@NJ1305 wrote:I am new to this Forum and I am sorry if this issue has been addressed before.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the response. The problem has been resolved. It was as simple as Forgetting the Network then selecting it again. It then asked for the password and connected when entered.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Problem resolved. It was as simple as Forgetting the Network them selecting again.
Thanks for your response.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
