DC1000
Feb 02, 2024Follower
AC2200 and RBS20 satellite compatibility
Hello I have the AC2200 mesh system with two RBS20 satellites. I need to add a third satellite, however cannot easily buy the RBS20 anymore as it is an older model. Are any of the newer satellites compatible with the older AC2200 system or am I now staring at replacing all units? Thanks
1 Reply
the newer ones won't work but there's quite a few models that are compatible. Plus, you can always pickup a renewed system and just use the satellites. That's sometimes cheaper than buying a stand-alone satellite.
Which Orbi routers and satellites are compatible? - NETGEAR Support
