- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AP Mode with Ethernet Backhaul with Firmware 2.5.1.16
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an RBR50 in AP mode and an RBS50 using Ethernet backhaul. Previously I had read that when you use Ethernet backhaul, Orbi will show all devices connected thru the satellite as "wired" devices which is exactly what I saw. After installing the new Firmware 2.5.1.16 on both the RBR50 and RBS50, all the devices connected to the Satellite are now showing as Wireless 2.4G or 5G, however they still show connected thru the RBR50. As a matter of fact, on the Network Map, the Satellite shows Pink with no devices attached. I didn't read anything in the release notes saying something had changed in this regard. Can someone verify that what I am seeing is indeed the way it is intended to be?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AP Mode with Ethernet Backhaul with Firmware 2.5.1.16
Anything similar to this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there switch in between the RBS and RBR?
Does the RBS appear correctly on the RBRs web page?
Has a factory reset been performed and setup from scratch?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes there is a switch between the two. Does that make a difference?
On the webpage, the Satellite shows as a connected satellite with Good backhaul status. (Shows the Connection Type as 5G which is a bit confusing.) However, none of the 42 devices shows connected to it. They all show connected to the Main AP.
Also, on the Firmware Update page, the Satellite status shows "Waiting for Connection"
A factory reset and scratch setup has not been performed recently. If that is recommended, should I reconfigure it from the wired connection or from a wireless connection first?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
It can, What is the Mfr and model# of the ethernet switch in the configuration?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am using a Netgear GS108t switch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, this is a managed switch. These switches have been known to cause problems between RBR and RBS.
Check to see if you can disable the following on the switch, IGMP and Green Ethernet features. Then power off the RBS and RBR for 30 seconds then back on. Hopefully this will help get the RBS connected correctly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, IGMP and Green Ethernet were already disabled on the GS108t. To reiterate from my original post, everything seems to be working well and I can tell that certain devices do home on the satellite. (How can I tell this? Strength of connection, range of main and satellite, etc.) It's just that the Orbi app and webpage don't report things properly. Is that normal for a wired backhaul?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You maybe running into what I'm seeing with others and the Orbi app:
You can post there as well or make a new post ther about what your seeing with the Orbi app. It it's own animal.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya, hopefully NG will figure the Orbi app out.
I would use the RBR and RBSs web page for now to see the status.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
