× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
AT&T hot spot connection
TIJ
Follower
Follower
Can the Orbi system be connected to my AT&T Hot Spot?  Via wifi?
Message 1 of 4
Accepted Solutions
Guru
Re: AT&T hot spot connection
No. The Orbi system requires a connect to a ISP Modem or ONT service, i.e. Cable modem, DSL or Fiber...
Message 2 of 4
All Replies
Guru
Message 2 of 4
Guru
Not via wifi.
What att hotspot do you have? some hot spots have a dock that give you access to an ethernet port.  You could look for accessories for your hotspot to see if this is an option. This would allow you to hook up the orbi but the orbi would need to be in ap mode. the hot spot will also usually limit you to a set number of devices.
Message 3 of 4
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2252 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
