- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Access Control on RBR50 with V2.5.0.38 firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since that last firmware upgrade the systems Access Control is all a mess. It even managed to Block one of my Satellites so I ended up having to turn off Access Control. Also I fear that if I reboot the system it will start randomly blocking things again.
"Blocked Outdoor back of house"
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Access Control on RBR50 with V2.5.0.38 firmware
Has a factory reset and setup from scratch been performed since last update? I believe someone posted about this not too long ago with similar issues with access controls. I believe it was resolved with a reset of the RBR.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Routerand RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the fast reply, No I have not tried a factory reset of the router yet... I did see that mentioned on a search but wanted to post here before I did that to see if that was the only solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seen odd issues with this FW update. Resets seems to help fix most of them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@AkoreJepade wrote:Since that last firmware upgrade the systems Access Control is all a mess. It even managed to Block one of my Satellites so I ended up having to turn off Access Control. Also I fear that if I reboot the system it will start randomly blocking things again.
STOP....V2.5.0.38 has known issues. Your best bet is to revert to an earlier version and STOP performing mmanual updates to your firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know if the reset fixes what your seeing.
Also be sure to clear out all browser caches as well. Get a fresh from the web page.
Not seeing this with v38 loaded. Manual FW upated and factory reset the RBR for mine.
@AkoreJepade wrote:Thanks for the fast reply, No I have not tried a factory reset of the router yet... I did see that mentioned on a search but wanted to post here before I did that to see if that was the only solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Let us know if the reset fixes what your seeing.
Hopefully they was NO Factory Rset...
Good for you, then you have no problems therefore have nothing to add.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
After a power outage Access Control configurations shouldn't change any.
I would make contact with NG support about this and let them know about it.
@AkoreJepade wrote:
Performed a factory reset yesterday and everything seemed to work fine until late last night when thunderstorms came through and knocked out the power, this morning random devices where Blocked in Access Control again. 4 devices, 3 Sonos players and one computer... Going to have to leave Access Control off and hope that the next firmware update they roll out fixes it.
