HaroldCPA's avatar
HaroldCPA
Follower
Jun 03, 2021
Add satellite-rbr50
I curreently have rbr50 with router and 1 satellite.
i tried to additional satellite from another system
I was able to synch new satellitee to router,
The router uses the ssid and password from my att system
During setup it told me to reboot the system.
After I rebooted I had to sign in to the app and it would not accept my existing password and would not allow me
to put in the existing admin login in
When I rebooted did it change my existing settings to what was on the satellite from another system?
Not sure what to do to get back original admin id and password
BTW I addede the satellite to strengten the signal to a ring camera located on the outside of my house
Any help would be appreciated
Thanks
1 Reply
  • michaelkenward's avatar
    michaelkenward
    What is the model number of this "another system"?
    You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's complicated community structure.)
    Many questions apply to different types of device, so you might get responses here, but Orbi systems are not like standard routers, so you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
    Orbi - NETGEAR Communities
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
