Orbi WiFi 7 RBE973
Reply
Amcrest Cameras, AT&T WiFi Router and Orbi
lskbaker
I cannot see my Amcrest cameras with Orbi as my WiFi. See them fine with AT&T WiFi. How do I work around the Orbi settings to see my cameras again?
Message 1 of 7
Guru
Re: Amcrest Cameras, AT&T WiFi Router and Orbi
LIke @vajim says, what att gateway is it?
If it has its own integrated router, it causes a double nat.
What is Double NAT? | Answer | NETGEAR Support
this can create the issue you're running into.
options?
1. put the att in passthrough/modem only mode
2. put the netgears IP address into the att devices dmz
3. put the netgear into access point mode.
(only use one of those methods)
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 7
lskbaker
I have more than one camera. AT&T modem is bgw210.
Message 3 of 7
lskbaker
One router brings internet in and WiFi is off and Orbi is set for wifi
Message 4 of 7
Guru
shutting off wifi doesn't disable router functions or put the att device in modem only/passthrough  mode.
Try using one of the methods described above.
Message 5 of 7
lskbaker
The Orbi is already in AP mode. You said one of the three right? So I’ve put the Orbi in AP already and that didn’t help me connect to camera. Do I then try passthrough mode or adding the IP address and not both of those?
Message 6 of 7
Guru
after the orbi is in access point mode, reboot the complete system (router, att device, cameras)
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1181 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
