- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
BRB50 loses WIFI internet after firmware update
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: BRB50 loses WIFI internet after firmware update
Hi I have exactly the same issue, did you find a solution?
- Mark as New
- Bookmark
- Subscribe
- Permalink
When problems come up immediately after installing new firmware, it might be time to consider downloading the previous firmware from the Netgear support site and manually installing it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
One thing to try after a FW update is power off for 1 minute then back ON with the ISP modem/ONT and Orbi system.
Or try a factory reset and setup from scratch on the RBR, with powering off the ISP modem/ONT for 30 seconds then back ON.
@Musashi_Vega wrote:Hi I have exactly the same issue, did you find a solution?
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
A reset on the RBR would be needed as well as the RBS.
Good Luck.
