Orbi WiFi 7 RBE973
Reply
Backhaul Status Poor
kensparker
Follower
I have checked and followed all recommendations for this with my 3-unit Orbi system.  None of them have resolved the issue.  Can anyone please suggest the fix?
Message 1 of 2
Guru
Re: Backhaul Status Poor
Is the Orbi system operating in Router or AP mode?
Is the RBS wired or wirelessly connected to the RBR?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 493 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
