jay540's avatar
jay540
Tutor
Jan 28, 2020
Beamforming and MU-MIMO Disabled by Default
I purchased my Orbi yesterday and setup in AP mode after much trial and error. Everything seems to be running fine. I have Fios as my ISP. My firmware on both the Orbi router and satellites were updated as well during the install.
I saw, under Advanced Wireless Settings that the Beamforming and MO-MIMO options have been disable by default. I must admit I am not sure exactly what these features are, however, it seems these features makes the wireless experience better and that is why we purchased these pricey babies. My search in these forums indicated that these features should've been updated in previous firmware updates.
My question, should I enable these features. What are the pros and cons. Any help is greatly appreciated.
  • FURRYe38's avatar
    Beamforming should be enabled. Helps in wifi performances.
    https://www.smallnetbuilder.com/wireless/wireless-news/32078-netgear-announces-draft-11ac-beamforming-upgrades
    MIMO is for devices that support MIMO and mostly it can be enabled. In recent past few years MIMO devices have become more prominent and on wifi routers. If you don't have any MIMO devices this feature can be disable. https://www.smallnetbuilder.com/wireless/wireless-features/33100-why-you-don-t-need-mu-mimo
    Same here. The MIMO functionality specifically.  WiFi calling works reliably with it enabled.
    • FURRYe38's avatar
      I presume NG may want to let the user enable these or not. There are some older devices out there that or not MIMO supporting. I think Beamfroming should be enabled by default. One can always disable it if need by for troublshooting. :smileywink:
      • gr8sho's avatar
        gr8sho
        Virtuoso
        DNK what NG is thinking here.  I wonder how many customers bought this product and have no idea these features are buried deep in a settings screen they're unaware of.  And I'm also unclear what the downside is of turning them on by default even if no active devices use the features.
