- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Beta Firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having all kinds of issues with the latest update. I am getting disconnects and speed issues. I was running an older version of firmware but the system will not allow me to downgrade back. It automatically updates back to the latest. Any idea how to get the latest beta?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please post the issues you are having or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Beta Firmware
Which orbi model are you using, Is it RBR40 or RBR50 ?
Are you getting disconnection and speed issue on all devices ?
For RBR50 I GUESS THERE IS A BETA FIRMWARE NOT SURE ABOUT RBR40 . YOU CAN REACH OUT THE ORBI TECH SUPPORT @ 888NETGEAR .
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Beta Firmware
It's the RBR50. I am noticing my iPad will drop wifi and then reconnect after about 30 seconds. I have a nest cam which disconnects every so often. Also, noticed my MacBook was connected to wifi but could not reach anything on my network (pings failed) until I turned wifi off/on on my MacBook.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Beta Firmware
Hello Mike,
you can try the new bta firmware ( V1.12.0.12) but before updating the firmware make sure that the Implicit beamforming and Mu-Mimo is disabled .
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Beta Firmware
Yes you are right the latest beta firmware is V1.12.0.16 .Which will an official one soon.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Beta Firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Beta Firmware
Does anyone have a push date for V1.12.0.16? I have beamForming turned on, will this be an issue if the FW is automatically updated?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Beta Firmware
not at this time
if beam forming is working for you now it should work when new fw is pushed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Beta Firmware
Can we turn on the MU-MIMO feature on yet? Or do we need to wait for the next Firmware? (assuming current Beta has it fixed).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Beta Firmware
i have had mine on for ages and nothing has been a problem , this you will only know if you turn on and test in your location , if it doesnt cause issues then leave it on , if it does cause issue leave it off for now and report the issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Beta Firmware
I am on beta 1.12.0.12. MU-MIMO and beamforming on. No disconnects. I have over 60 devices connected including Dropcams and I have been running the beta for a week with no issues. I think we may finally have a winner.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Beta Firmware
Hearing good things about beta 1.12.0.12. I am getting SAT drops. Lets hope they PUSH out as auto update soon.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Beta Firmware
Even more good things about the latest beta. A very, very, very long-standing issue has finally been corrected - can't say more, but it's been a hot-button issue for me particularly for quite a long time. The final release should make a lot of folks pretty happy.
Rodney
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Beta Firmware
I hope so my friend. I really want this setup to be stable or I may need to return it by 7-20-2017. I am holding off on youtube review b/c of beta. Wife is not happy after spending $400 on a setup that does not stay up. and my ranch is open floor plan 2,200 sq ft LOL... I will keep you all posted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Beta Firmware
I brought this up in another thread as someone mentioned not being able to now turn off 2.4ghz completely in Beta, posting this question in this thread as it is for the latest Beta. Why was the option to completely disable 2.4GHz removed? I have zero legacy devices on my network and have currently 2.4GHz disabled and want it disabled.
This would be a deal breaker for me I have had the Orbi since release and very patiently dealt with the growing pains. If they remove this feature to not be able to disable 2.4GHz I am with a sad heart going to get rid of Orbi.
Netgear if are reading this PLEASE put this option back in please give us the option and not force things on us everyone needs and environment are different!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Beta Firmware
think you are confused here as all you adapters will work on both 5 gig and 2.4 gig and it just depends on how far away from the router or sat as to when your device steeers its self to 2.4 gig
turning off 2.4 gig on the orbi and your client has no option and just hangs on to the slow low signal which effects its speed and connectivity , the whole reason to have band steering is to enable your client devices to have better connectivity over greater distances and overall better stability
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Beta Firmware
@peteytesting thanks for the detailed explanation I understand that, but I still don't see the logic to take away the option to disable 2,4GHz those who want both on can those who don't have the option just silly to take the option away, competitor products offer the option to disable 2.4GHz.
In my environment speeds and range were fine using only 5GHz radio. I have 12 wireless devices running on 5GHz speed and ranges are fine for my needs. I do not have the need nor do I wish to enable the 2.4GHz radio, please do not force me to.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Beta Firmware
Orbi has a hidden network on the 2.4 GHz band. It's there for some reason. If you read the Netgear patent application for Orbi, it talks a lot about using all the different radios (2.4, 5, and dedicated 5) for the backhaul.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Beta Firmware
It'll use 2.4GHz backhaul if the 5GHz connection is lost, though it's really only used to tell you "hey, you need to move the satellite closer to the router". Used as actual backhaul, it'd suck pretty badly.
Rodney
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Everyone
Thanks
DarrenM
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
