×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Blocked sites
Maryann972
Blocked sites
Why are many sites blocked with 404 Not found!
So very frustrating to view recipes & shop.
Message 1 of 8
Guru
Re: Blocked sites
So what product are you referring too?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 8
Re: Blocked sites
And where do you see these messages?
A browser? Which one?
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 8
Guru
Re: Blocked sites
As @michaelkenward @FURRYe38 have implied, more details are needed.
What modem/gateway do you have?
What router is it connected to?
Firmware on the router?
do all devices have this issue? or just one?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 4 of 8
Maryann972
Re: Blocked sites
Most sites are blocked stating 404-file or directory not found. This new router is blocking everything!
Message 5 of 8
Guru
Re: Blocked sites
And you didn't answer a single answer above. We can't help you without details.
If you just bought it, you can contact support. You have support free for the first 90 days of purchase (if new).
click on "mynetgear' register an account and the device. from there you can contact support.
Message 6 of 8
Re: Blocked sites
Sounds like you have a problem with this technology stuff.
If you can't find the answers to the questions that people have asked you – there are plenty more where they came from –  I suggest that you return the thing to whoever supplied it and buy something else.
Explain your problem to them and they may offer an easier alternative
Message 7 of 8
Guru
Re: Blocked sites
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 517 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
