× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Bricked Orbit - Failed Firmware Update
CaptStevo
Star
Hello all,
I attempted an update to the 2.1.4 firmware tonight, and apparently didn't upload the entire file in the process of updating my router unit.
The orbit now powers on with a solid white ring, flashing power LED, and no access to the web GUI.
I tried several resets, and tried to TFTP the firmware image with no success. Has anyone had success getting support for something like this? I have had my unit for over a year so I'm worried I'm out of luck with a bricked unit.
Thanks for any help.
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 8
Accepted Solutions
CaptStevo
Star
Re: Bricked Orbit - Failed Firmware Update
Well, I owe you a cold one for the hint to use the built-in TFTP client to attempt my unbricking.
It worked!
For anyone who has the same problem, I've highlighted what I used below in case you aren't as command-line savvy.
My problems started after having my browser crash at about 85% through the upload doing a manual firmware update. I let the router sit for almost 30 minutes, but from then on, it would have a solid white light with an (eventual) flashing green power LED.  No amount of resets or power cycles would get it out of this state.
So, I used the above mentioned article to factory reset the Orbi, and after waiting for the amber LED, then 10 flashing green LEDs, used the command: tftp -i 192.168.1.1 PUT path_to_your_firmware.img
My screenshot looks a bit different, as I'm using Windows Powershell, not the regular command line.  When it's done, it should show "Transfer successful" - now wait!  The Orbi takes a few minutes to power-cycle and get set up.  Head to orbilogin.com and complete the initial setup.
Here are a few links to get set up with Windows TFTP and a guide on how to flash.
Install TFTP on Windows 7/10: https://www.pcwdld.com/tftp-client-for-windows-7
Use TFTP to flash via command-line: http://visihow.com/Perform_a_firmware_recovery_on_a_router (Use STEP 7)
Thanks again, disaster averted!
Message 5 of 8
All Replies
Guru
Did you use this method to recover the router? Be sure that you enabled TFTP on WIndows and not use this linked TFTP app here. Some said it doesn't work vs Windows does.
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
If you can't seen to recover, please phone contact NG support...
Message 2 of 8
CaptStevo
Star
Thanks, I'll give the built in TFTP client a shot and report back.
Message 3 of 8
Guru
Hope it works...
Message 4 of 8
CaptStevo
Star
It worked!
Message 5 of 8
Guru
Awesome. I like beer too man. LOL.
Glad you go it working.
One thing to keep in mind for doing any manual FW updates, I recommend using IE11 or FF browsers for doing FW updates. Don't let any mobile apps do it. Use a PC or Laptop. Also be sure if you do manual updates, connect with a PC or laptop with a LAN cable. Do not perform the update via wireless. This can present problems as well using wireless.
Also disable any PC security browser plug ins or OS platform security temporarily while you manually update. Re-eanable after updating.
Enjoy now.
Message 6 of 8
TwistedK
Tutor
Thank you. Came here looking for this. Worked for me too!!
Message 7 of 8
Guru
Enjoy.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 13112 views
  • 12 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
