- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Buying a used satellite for my RBR50?
- Mark as New
- Bookmark
- Subscribe
- Permalink
There are quite a few Orbi kits for sale on the used market but I have read that not all models have a dedicated backhaul like the RBS50.
Is there a list of models that I could look up before buying (to make sure I get a model with the dedicated backhaul)?
I realize that I would not be able to use a router as a satellite but if the price of the used kit is good, that would not matter.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The following models will work and have a backhaul.
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
Keep in mind, only the 50 series devices having the wider 1733mbps backhaul. The others use the 866mbps backhaul.
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Buying a used satellite for my RBR50?
Thanks for the quick answer @plemans
I don't see many 50s out there but the slower backhaul should be fine for most devices.
Are there any (other) performance considerations that I should keep in mind if I can choose between the models above? Higher the model number, the better?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Its more about ethernet port availability on some models. The RBS40V has a built in speaker for alexa. The RBS50Y is an outdoor rated satellite.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@plemans wrote:Its more about ethernet port availability on some models. The RBS40V has a built in speaker for alexa. The RBS50Y is an outdoor rated satellite.
Ah yes, ethernet ports would be nice as I could have a backhaul-connected-satellite in the basement and my devices connected to it by Ethernet. Some devices may not even have wifi for that matter.
- Mark as New
- Bookmark
- Subscribe
- Permalink
usually not a big deal as you can expand the ethernet connections with a simple unmanaged switch if you want.
I've done that before when I needed more on a satellite.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, understood. I have even older routers that I could use as switches (with wifi off). It's just another device to "look after" though. I'll try to avoid if I can...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
They're interchangable. You can go eitherway. I'd just add the satellite to your current setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Setup | Internet Fiber ONT 250↓/250↑ | ISP Telenor | Wifi Router Orbi RBR850 + RBS850 + 2x RBS750 + 3xRBS350, Wired/Wireless BH / Orbi RBR50 + 6x RBS50 + RBS40V + RBS50Y, Wired/Wireless BH | Switches NG GS208 | Time Zone CET (Sweden)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ekhalil wrote:
I would use the RBS50v2 as the main router. My experience is the v2 is faster and more stable than the v1.
I've got a v1 and v2. I haven't noticed much (if any) difference between the 2.
I've noticed differences between firmwares but not between the versions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The used RBR50 kit was already sold when I contacted the individual. 😕
Tell me @plemans (or anyone), could this be an opportunity to upgrade my RBR50 kit and just use my current RBS50 as a satellite to the new router? 🤔
Or should I just try to grab one of the compatible satellite listed in this thread and avoid the hassle? 🙂 And there are more of those like the RBK20 kit on the used market (and cheaper too).
Speed is not a big big concern but I see that my Xfinity tv box is connected to my satellite at 780mbps which would not be possible with other satellites (such as the RBS20).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Alas, satellites from the various Orbi product lines do not function with routers from other product lines. The newer AX products, for example, use 802.11ax for the satellite to router link, which a different radio chip that is different from the radio chip in the RBS50. Even products with the identical "insides" are not compatible: Original Orbi and Orbi Pro have identical hardware, but their software is not compatible.
Annoying situation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@CrimpOn wrote:Alas, satellites from the various Orbi product lines do not function with routers from other product lines. The newer AX products, for example, use 802.11ax for the satellite to router link, which a different radio chip that is different from the radio chip in the RBS50. Even products with the identical "insides" are not compatible: Original Orbi and Orbi Pro have identical hardware, but their software is not compatible.
Darn. 😕 Thanks @CrimpOn.
Is that true of all models or are there some that would work with RBS50?
Seems like the SRK60 would work with the RBS50. Not sure if the SRK60 is that much better than the RBR50 though. 💁♂️
- Mark as New
- Bookmark
- Subscribe
- Permalink
An RBS50 will sync with any of the 'original' Orbi 802.11ac models
RBR50
RBR40
RBR20
The major difference between the RBS50 satellite and the satellites that were packaged with those other routers are:
- More ethernet ports
- High speed backhaul (satellite to router) connection
I got a used RBR50 from eBay and it has worked for a couple of years. (It's my 'backup' and I also use it for messing around.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes @plemans, I have not forgotten (yet). The (latest) question was about the other way around (since I could not get the used RBK50 kit); that is buying a new (better) router and connect my RBS50 satellite to the new router. 💁♂️
- Mark as New
- Bookmark
- Subscribe
- Permalink
If only as courtesy to those who have advised me, I was able to snatch a set of two used RBS50 (with a router) on eBay and easily connected them to my network. Obviously, I am not using the router although I think I have read somewhere that someone was able to turn a router into a satellite through some kind of firmware update.
Thanks to all.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad its up and working. There is a way to convert and rbr to and rbs but you won't find it on the official forums. And it can easily brick the router. Might be better tto hold onto as a backup router. With having a decent investment in satellites, if the router goes bad, at least you can still get everything up and running
- Mark as New
- Bookmark
- Subscribe
- Permalink
@plemans wrote:Glad its up and working. There is a way to convert and rbr to and rbs but you won't find it on the official forums. And it can easily brick the router. Might be better tto hold onto as a backup router. With having a decent investment in satellites, if the router goes bad, at least you can still get everything up and running
Yes, agreed. I don't need any more satellites anyway. 🙂
