Orbi WiFi 7 RBE973
Reply
Buying additional RBS20 satellites for CBK40?
dstranathan
Apprentice
I rcenlty bought the new 2018 RBK40 mesh kit (which included 1 CBR40 modem/router combo and 1 RBS20 satellite).
Id like to eventually add an additional satellite.
Can I buy an additional RBS20? Can they be purchased individually, or must I buy a different satellite model?
What is the difference between the RBS20, RBS40 and RBS50 models?
Model: RBK40| Orbi AC2200 WiFi System
Message 1 of 4
Guru
Re: Buying additional RBS20 satellites for CBK40?
Yes, you can. I would suggest only using up to 3 satellites.
You find spec info here about each system.
https://www.netgear.com/orbi/systems.aspx
Scroll down to towards the bottom of the page for each model to see spec info.
Mostly the 50 series is (1733 + 866 + 400Mbps)
The 40 series is (866+866+400Mbps)
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 4
dstranathan
Apprentice
Thanks. But where can I BUY the RBS20 individually?
Message 3 of 4
Guru
Only satellites i see available individually is on amazon:
https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Delectronics&field-keywords=netgear+rbs5...
I don't see RBS20s though...
@DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4354 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
