- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CBR40 random loss of connectivity
- Mark as New
- Bookmark
- Subscribe
- Permalink
ORBI CBR40 running the latest firmware on COX 150M/10M.
My issue to say the least is weird. I went back to my old Zoom modem because I'm experiencing loss of connectivity to my work environment.
!'m connected via Palo Alto Global Protect VPN to work and then all of a sudden Microsoft Outlook, Skype, & Teams, Cisco IP phone, and Remote desktop applications all disconnect.
I check Global Protect and it says its connected. I text my co-workers and ask if there's an issue and they say they're fine. I do a speed test and get speeds anywhere between 20M-40M down and 0M-2M up. I'm thinking its a COX issue! They've sent technicians out, replace the cable lines, I'm still having the issue. That is till I went back to my old Zoom modem. So far NO issues to where I stay connected to the VPN and application disconnects.
When I'm experiencing the application disconnect while on the CBR40 its a bouncing situation. The apps would connect for a minute or so then disconnect. I've had COX reset the CBR40 from their side. I've tried factory reset, disconnect all other devices on the CBR40 and yet still the issue persists.
I purchased the CBR40 on Apr 30, 2020 and received it May 7th, 2020 and installed it the same day and since that day I've experience this issue of my work applications disconnecting, the VPN staying up, all other devices are able to web-surf, COX internet speeds of 20M-40M down and 0M-2M up while having the issues.
I'm not sure if any has these issue or even something close to it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CBR40 random loss of connectivity
- Mark as New
- Bookmark
- Subscribe
- Permalink
Press the back reset button for 15 seconds then release.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
