Orbi WiFi 7 RBE973
Reply
Can I connect a CM500V and Orbi CBK40 on Xfinity
Sturg62
Follower
I know CBK40 does not support ISP embedded voice on cable from ISPs. I have Xfinity as my cable provider and use aCM500V router for cable and phone. Won an Orbi CBK40 in a silent auction package and want to know if I can use it just as a wifi router by hooking it to CM500V through ethernet port to preserve my phone line
Message 1 of 2
Guru
Re: Can I connect a CM500V and Orbi CBK40 on Xfinity
No. There two separate modems that work as modems. The CBR40 can be bridged, however this disables the wifi on the CBR40 and makes it just a modem only.
Your best option if you want voice support, keep the CM modem and return the CBK40 system and get a Orbi RBK40/50 system.
https://www.netgear.com/orbi/wifi-systems.aspx
These systems don't have the built in cable modem and it's just the wifi router features that you would need to work with the CM voice modem.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 788 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
