×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Can I use telnet through Orbilogin.com?
Dogzelda
Follower
I have my Orbi system set up as an Access Point behind my U-verse router. I can not access the system through 192.168.1.1. Is there a way to use the telnet features through Orbilogin.com? If not, does anyone else have a suggestion of getting into the system since I can not do it through 192.168.1.1
Model: RBK22| Orbi AC2200 Tri-band WiFi System
Message 1 of 4
Guru
Re: Can I use telnet through Orbilogin.com?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Depending upon what the Orbi router is getting from the ISP modem IP address wise, this will me how you connect to telnet on the Orbi, so if the Orbi changed it's LAN IP address to avoid a confllic with the ISP modem, it maybe now using 191.168.0.@ or a 10.something address pool string on the LAN side. Use this IP address string to connect to telnet.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 4
ekhalil
Master
This is because the U-verse router is another router in your network.
Please disconnect the U-verse router, restart Orbi and log in to Orbi with oebilogin.com.
After that you need either to set the U-verse router into bridged state or set Orbi into AP Mode.
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBR850 + RBS850 + 2x RBS750 + 3xRBS350, Wired/Wireless BH / Orbi RBR50 + 6x RBS50 + RBS40V + RBS50Y, Wired/Wireless BH | Switches NG GS208Time Zone CET (Sweden)
Message 3 of 4
ekhalil
Master
Once you disconnect the U-verse router you should be able to login to Orbi using 192.168.1.1 (if you did not change the default DHCP range in Orbi).
Message 4 of 4
Discussion stats
  • 3 replies
  • 2214 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
