- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
Can't change icons of attached devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't change icons of attached devices
The Netgear Support team finally gave me a beta version of the V2.5.1.8 firmware for my RBR20 router and RBS20 satellites. I can confirm that it in fact resolved my issues.
While this version has been officially released for the RBR50 product line, it is not yet released for the RBR20. I am told it will eventually show up as released however.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Awesome. Thanks for letting us know. Enjoy.
@Keith_1952 wrote:The Netgear Support team finally gave me a beta version of the V2.5.1.8 firmware for my RBR20 router and RBS20 satellites. I can confirm that it in fact resolved my issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any news on when the FW will be released to the public ?
Can you send me the 2.5.1.8 beta for my RBR20 & RBS20 ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Looks like Netgear has abandoned us on the FW upgrade. That said, Here are links to the Beta they send me which I installed, and is working:
Router:
https://kgreer.net/RBR20-V2.5.1.8.zip
Satellites:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Great. Thx.
Unfortunately both links down the RBR. The RBS is not behind the second link.
- Mark as New
- Bookmark
- Subscribe
- Permalink
update: Sorry, now it's working. link in email was broken, link in forum worked out well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there a chance you also got the FW for RBW30 ? I got that one "plug"-satellite as an addition in my mesh.
Best
- Mark as New
- Bookmark
- Subscribe
- Permalink
I edited the links in the post, and tested them. They work now. Try again.
@proeder wrote:Great. Thx.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nope. Don't have anything for the RBW30, sorry.
@proeder wrote:Is there a chance you also got the FW for RBW30 ? I got that one "plug"-satellite as an addition in my mesh.
Best
- Mark as New
- Bookmark
- Subscribe
- Permalink
The link targets to the beta firmware have been removed per Netgear's request. You'll have to wait for the production release.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router Firmware Version V2.3.5.32
I found this thread through an internet search because like a lot of you I too could not change the icon on some of the devices on my list of attached devices. Through trial and error I found I could change *some* of the icons, the ones at the top of the list. Having a bit of a web app/database background I suspected some kind of issue with the database, so I worked my way down until I found a particularly long device name. Everything after that entry exhibited the error condition (icon changes would not be saved).
So I shortened the device name and saved it, then tested the items that previously could not be changed. Voila! Fixed.
What I suspect here is some sort of back end change to the data storage structure that was not reflected in the web interface, resulting in unchecked input validation causing a database issue (most likely exceeding the allowable characters in a field).
TL/DR: Look for long names in your list of devices. If you can change the icons before that one but not after it in the list, shorten the name.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I believe this was it (fortunately I'd saved a spreadsheet with all the info prior to wiping out the name):
LSD Science and Technology Co.
So looks like 29 characters. Could also be a function of the whitespace and period, or some other character that I'm too bothered to figure out. Once I shortened that to "LSD Science" I was able to modify and save icons farther down the list.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. Another "activity". My longest device name is 20 characters.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ah, good luck then. Knowing they have issues with unchecked input, you might check your names for extended characters especially ones that have system usage in linux (like \ and @, etc.).
- Mark as New
- Bookmark
- Subscribe
- Permalink
FW Update solved the icon problems. Just flip to 2.5.1.16 with RBR20 & RBS20
- Mark as New
- Bookmark
- Subscribe
- Permalink
This did not work on my RBR40 with the latest firmware. The icon issue persisted until I shortened the offending device name.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@richbusby wrote:So looks like 29 characters. Could also be a function of the whitespace and period, or some other character that I'm too bothered to figure out. Once I shortened that to "LSD Science" I was able to modify and save icons farther down the list.
It may be an issue with "characters", but it is not an issue with length. I changed the device name of the 3rd device in my list to the full 32 character device name limit and found that I can still change the device icon on devices farther down the list. (The input field actually "cuts off" after 32 characters are entered and does not accept any more.) It is a little annoying that after clicking "Apply", the pop up window disappears and it is necessary to click on "Refresh" to see that the change took place. Or, perhaps wait until the screen automatically refreshes?
Almost all of my device names have one or more spaces in the name.
This is an Orbi RBR50 with firmware 2.5.1.8. So, I'm stumped.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do remember I'm running a different model and firmware so this is not an Apples to Apples comparison. The key thing to keep in mind here is that we have an observed issue with the GUI versus the database and a likely unchecked input validation condition i.e. the GUI accepts illegal or otherwise problematic characters that has problems once it hits the table/matrix/database/whatever they are storing the data in.
Have you tried going down to very basic device names with absolutely no extended characters? Cutting and pasting can pick up a lot of garbage so I'd type them in directly by hand.
My hardware:
Hardware Version | RBR40 |
Firmware Version | V2.3.5.32 |
GUI Language Version | V1.0.0.360 |
- « Previous
- Next »
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
