× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Can’t connect iPhone 13 pro to cbr40
LLJ
Star
Star
I have a cbr40 and my iPhone won’t connect to it. Internet and Wi-Fi are working but I can’t get into the app to do anything. Tech is not a strength for me so maybe I’m missing something very simple. I’ve pushed the reset button, I’ve unplugged the unit from power then plugged it back in after several minutes. My only thought is to delete the app, download it again then see if I can get into it. I’ve read there are some issues with this so I’m hesitant to pull the trigger on this. Can anyone help me fix this. Many thanks…
Message 1 of 5
Guru
Re: Can’t connect iPhone 13 pro to cbr40
Are you able to log in through the browser?
When the app's having issues, that works for most.
also, make sure on the apple that icloud relay and random mac/ip is disabled. I've seen that cause issues with the app
Message 2 of 5
LLJ
Star
Star
Thanks for your quick response. I’m a bit slow when it comes to this stuff… can you tell how to make sure on the apple that icloud relay and random mac/ip is disabled?
Thanks again…
Message 3 of 5
Guru
Message 4 of 5
Guru
Any progress on this?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1019 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
