× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Can't connect orbi to internet during set up
Lucylou2020
Follower
I am having problems connecting Orbi to the internet. I get all the way through set up, cable says its connected fine but the internet connection is not.
Do I need a PPPoE user name and password, or Do I need an IP address?
My internet provider is a no frills provider so I can't ring them and they are saying its a product issue.
Has anyone had this problem or does anyone have any solutions.
Thanks
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Can't connect orbi to internet during set up
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? There a built in router here by chance?
Is your ISP cable or dsl?
If our modem already has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 656 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
