Orbi WiFi 7 RBE973
Reply
Can't install Orbi mytime on childs Kindle-Fire HD (2019)
clicker1
Follower
Advertising all over the place tauting support for child protection via mytime using Orbi, on Amazon Kindles.  Major challenge:
1. Orbi mytime-install link take syou to a google marketplace, which only installs on known devices.
2. APK's don't install directly onto kindles without 3rd party software
So can someone direct me to the step-by-step Kindle installation instructions for the mytime app?  Or was this all just "assumptions" on Product Managements' part because android was supported?
Use Case:  As a parent and owner of a Kindle device, I would like to install and configure the mytime application for managing my childs online saftey, by following step-by-step instructions given that the application is not registered on the Amazon Marketplace for Kindle.
@orbisupport @NetgearSupport_
Model: SRK60B06|Orbi Pro Tri-Band Business WiFi System
Message 1 of 2
Guru
Re: Can't install Orbi mytime on childs Kindle-Fire HD (2019)
Netgear has set up a community forum specifically for this product. Most of the people who watch that forum are more likely to have experience with MyTime and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/bd-p/en-home-smart-parental-controls
https://kb.netgear.com/000062089/How-do-I-set-up-and-install-the-My-Time-by-NETGEAR-app
Good Luck.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 715 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
