Orbi WiFi 7 RBE973
Reply
Can you sync an Orbi satellite to an outdoor Orbi?
lilbooker
Follower
Hi,
Should it be possible to sync an Orbi satellite RBS20 to an outdoor Orbi RBS50Y via the sync button on both devices? This is to say NOT pressing sync on the main router.
The satellite I have is not syncing to the outdoor Orbi in this method for some reason, and I do not want the satellite to sync to the router but rather the outdoor Orbi since it is in much closer range to the satellite than the router.
This arrangement worked for several years and now all of a sudden the satellite will not sync to the outdoor Orbi, but instead is trying to sync to the main router, it seems in the network map.
Please help, thanks!
Message 1 of 2
Guru
Re: Can you sync an Orbi satellite to an outdoor Orbi?
Should work I think...something to try.
I would make sure FW is up to date on each.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 213 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
