×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Circle Firmware Outdated and won’t update
mcphael
I just installed the Netgear RBR50 Orbi and attempted to set up circle. I received a message that the firmware needed an update. I was prompted for my user name and password which kicked off the update but then it generated an error saying something was wrong with no specifics. Can anyone help?
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 6
Guru
Re: Circle Firmware Outdated and won’t update
What FW is currently loaded?
Manually download the FW update file from NG support site and then apply them with a wire connected PC. Update the satelite first then the router.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 6
mcphael
Currently firmware 2.0.1.4 is loaded on the Orbi.
Message 3 of 6
Guru
You need to load v2.1.4.16 to the satellite then router lastly.
Download the files from NG support site for your model Orbi:
https://www.netgear.com/support/
Message 4 of 6
rahuln
Hi,
I'm also getting the same error. I'm running v2.1.4.16 on both router and satellite for RB50 and RBS50. Anyother fixes?
Thanks
-Rahul.
Message 5 of 6
Guru
I would contact NG support and ask about this...
@rahuln wrote:
Hi,
Thanks
-Rahul.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1032 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
