- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connect USB disk to RBK53
- Mark as New
- Bookmark
- Subscribe
- Permalink
I ordered a mesh system with 3 Orbi AC3000 (RBK 53). I need to set up a USB hub on one of the hubs. Anyone know of a good ethernet to USB 3.1 type 2 hub - I need to hooking up 12 disks. Running a 50 foot cable across the house is not an option. Hooking up the disks directly to my computer is not an option (mostly due to space). Wondering if I ordered the wrong solution and need to return it for a solution that has built-in USB.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connect USB disk to RBK53
Unfortuneately no, users been asking for USB drive support from Orbi for a while now. V2 Orbi AC and now Orbi AX doesn't even have the USB port in the back. Sorry.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi does not support ReadyNAS or USB disks. The RBK53 v2 does not include a USB2 port, nor does newer models. It does not appear that NG plans to support any USB devices going forward.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am aware the RBK53 (Orbi AC8000) does not have a serial port (I purchased 3). I would be very surprised if I am alone with this problem. Therefore the request was if there is an ethernet<->USB device I can hang off the Orbi or a Wifi<->USB device that is not an arm and a leg I can connect to the Orbi. I found these:
but they seem overkill for features and the 8 port is over $1000. Maybe I can hang the 2 port off the Orbi and attach a multiport USB to that, but that seems overly complicated and about $400 as well. I have an Netgear that the modem is going out on (1-30 Mbps instead of 960 Mbps - or anywhere near that - on a Nighthawk C7000 (AC1900)!), maybe I'll see if the Nighthawk ethernet hub and USB 2.0 is working on that and try using it. Maybe I'll see if I can find a good configuration that has USB built-in.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You are asking for advice on a solution that has nothing to do with the Orbi. Your Orbi will support any wired network device you want to attach, including a USB hub like the one you listed.
For me, if I needed to attached 12 USB disks to the network simultaneously, I would build at a cheap Linux host with multiple USB ports and setup Samba CIFS shares of the disks out onto the LAN. Better yet, I would use a NAS with RAID1 or RAID5 for network disk storage (which is what I am currently doing).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd go for this one:
The idea of using that many USB devices fills me with apprehension.
- Mark as New
- Bookmark
- Subscribe
- Permalink
NAS is so nice. Ever since I got my several years ago, I have not looked back on USB drives. The ones I have are sitting collecting dust.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My old USB drives "daisy chain" down as another backstop at the bottom of the food chain. Or as portable drives for media stuff, for example.
