- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connecting Orbi router to a Nighthawk?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connecting Orbi router to a Nighthawk?
The cable should be connected to the WAN port in the Nighthawk.
Will Nighthawk's radio range interfere with Orbi's? If yes then you have to use a different SSID and r adio channel for the Nighthawk than the one in Orbi to avoid degradation in the Orbi.
My Setup | Internet Fiber ONT 250↓/250↑ | ISP Telenor | Wifi Router Orbi RBR850 + RBS850 + 2x RBS750 + 3xRBS350, Wired/Wireless BH / Orbi RBR50 + 6x RBS50 + RBS40V + RBS50Y, Wired/Wireless BH | Switches NG GS208 | Time Zone CET (Sweden)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The only other thing I'm questioning is that I had to put a new rj45 connector on the cat7. I wondered if cat7 cable accepts the same rj45 connector as a cat7. I wired it all up and used a tester to check. according to the tester everything is wired correctly and it is grounded.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mirama44 wrote:
Thank you for your fast reply. I dont understand your statement. What do I need to know/do to figure that out? Inside my out building I cannot get the orbi signal from my house. the outbuilding is about 120 feet away and it is a metal building. This is why I chose to run the cat7 underground and hardwire devices in order to ensure i can get internet in the outbuilding.
120 feet is quite a long distance, so I don't think you need to worry about the radio interference from the Nighthawk.
If there is not continuity between the Orbi system and the distant house there is not much advantage if you get an Orbi Satellite instead of the Nighthawk. The only advantage would be that you will be able to manage the whole network from one place (your browser or the Orbi phone app).
Regardng the cabling the color coding of cat7 cable is the same as cat6. But I think there are special modular plugs (shielded) for the cat 7 cables that are slightly different than cat 6.
A common mistake (that I once did) is to not use the small canal piece (see picture below) that comes with the plug without which the wires will never be in place. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think all you need to do is to ensure and verify the CAT lan cable from the main router out to the remote building is correctly wired and if so, then use the Orbi in AP mode in the remote building:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@mirama44 wrote:
Hello. I'm sure someone may have already asked this but I could use some help. I am trying to connect my orbi router with a cat7 ethernet out to an outside building. I have the cable ran from house outside but when i plug it into my nighthawk i dont get any internet signal. I wondered what port do i plug it into the nighthawk? Or, would it be easier/better to hook the cat7 cable i to another orbi device versus the nighthawk. I have spent some hours troubleshooting and testing to ensure the nighthawk is functional. The firmware is up to date. The nighthawk works find separately but when i hook it up to the cat7 coming from the orbi router, its a no go. Thanks for any/all assistance.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mirama44 wrote:
Real quick I was able to put the router into AP mode but then I couldn't connect to internet at all? I ended up resetting the orbi back to factory just so I could have internet. Just got done setting everything back up. Not sure what I should have done after changing it into AP mode?
No, you don’t need to use AP Mode in the main router. It has to be in Router mode.
Please get the Ethernet cable working and connect it to the WAN port of Nighthawk and hopefully everything will be working after that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mirama44 wrote:
......... When I tested the line with the tool I had, it said everything was wored correctly. That is why I was worried that maybe I need specific cat7 connector... Do you recommend any specific cat7 connector? I saw a 10 pack on amazon, and I emailed the company who I bought the cat7 from (haven't heard back). ............
If the cable works fine with the current connectors then you should be fine. The shielded cat7 connectors just improve the capabilities (range and frequency) of the cable. Please test that you have good signal on the remote side of the cable by a tool or by connecting a laptop and seeing the LED's on the LAN port of the laptop are on when the cable is connected to Orbi LAN port on the other side.
- Mark as New
- Bookmark
- Subscribe
- Permalink
After puting the Orbi in AP mode, did you reboot the NH router as well? You should have had internet after configiguring AP mode.
Be sure that your using the WAN port on the Orbi router for AP mode. You can try one of the LAN ports as well as a troubleshooting measure. AP mode works for others using other routers with the Orbi system.
Besure the LAN cables are good. Verify this with a PC and using them directly connected to the main host router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mirama44 How are things going for you? Hopefully all is well now? 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
The other person suggested go into AP mode. Then reboot the NH router. My concern was that when I put orbi into AP mode, then I couldn't connect to internet at all in my house....
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was wondering was I supposed to put the nighthawk into AP, not the orbi?
Thanks for help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Going back to your first message, it is not clear to me what the order of these things is.
Is it the Nighthawk that is at the far end of the long LAN cable? Or is it the Orbi?
The standard setup, and the one I have, is:
modem (in bridge or modem only mode) > router (in router mode) > Orbi (in access point mode)
Alternatively:
modem (in bridge or modem only mode) > Orbi (in router mode) > router (in access point mode)
The "modem mode" bit matters only if you have a modem that doubles as a router. (Look for a set of LAN ports on the back).
You plug the modem into the Internet port on the router. Then connect the Internet port on the AP (Orbi or NIghthawk) into a LAN port on the router.
When setting this up, you need to start things in the right order:
modem > router > access point
leaving time for each device to settle down before turning on the next bit.
It shouldn't matter, but I can't see any mention of the model number of your Nighthawk router.
I would check that everything works with router and AP close to each other before adding the complication of a long ethernet cable.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
Review these for configuring AP mode on the Orbi system:
@mirama44 wrote:
Helli,Hello, me again. I reread your post and you said to use WAN port on orbi router for AP mode. I'm not sure what that means. I have my internet provider cable coming into my orbi router into the yellow "internet" connection. I have my cat 7 in one of the Orbi's other connections running outside, underground in conduit about 150 feet to my outbuilding where my nighthawk router is located. I plugged the cat7 into the WAN port of my nighthawk router. I cant get internet. I plugged my laptop into the cat7 connector in the outbuilding and cant get internet. The other night you suggested to put orbi into AP mode. I put the orbi into AP mode but then I couldn't get internet anywhere in my house. I had to reset the whole orbi system and reset it up. I did retest my cat7 cable today and tester still reads that everything is good.
Thanks for help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
PLEASE READ!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Really.
@michaelkenward wrote:
@ekhalil wrote:
ORBI IN THIS CASE CAN’T BE IN AP MODE.
PLEASE READ!Please explain!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi is the only router. The Nighthawk is to be connected (wired) as an AP to Orbi to extend the range in a remote building.
He has a problem in the cable that needs to be fixed. I think that’s the only issue now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the Orbi is acting as the main host router, then they can configure the NG router for AP mode and connect it to the Orbi router at the remote location. The NH router needs to be connected via its LAN port to the Orbi's LAN port, not the WAN port when in AP mode. This will work.
IF the NH router is the main host router, then the Orbi can be used in AP mode at the remote location or a satellite or a Orbi router in AP mode can be used at the remote location.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yup. That's how I see it.
Choose one to be the router, set the other in AP mode.
As I said earlier, it is not clear to me which box is destined for which role.
If the idea is to have good wifi in the house, then using the Orbi as the router make sense. Then the Nighthawk goes in the "shed".
From what we read here, most people with an Orbi/Nighthawk combination tend to use the Nighthawk as the router, probably because it offers more control but the wifi isn't so good.
- Bookmark
- Subscribe
- Permalink
@mirama44 wrote:
Still no luck. I double checked wires again today and tester says all is good. Going to keep trying ......
@mirama44 To see if the cable is the issue, please get the Nighthawk near Orbi and -as was suggested by @michaelkenward- connect them with a short LAN cable and see if the Nighthawk (or a laptop connected to Orbi) will work, if it does then you know it's the long cable which is bad and you need to keep troubleshooting the cable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ekhalil wrote:
Please read the posts above.
I did. Several times. Carefully.
That is your assumption. It is not clear to me from the message I quoted.
I prefer to ask for clarification than to jump to conclusions.
I offered suggestions based on either scenario. Seems that I was in line with @FURRYe38's thoughts.
It is up to @mirama44 to decide what to do.
Not sure about the port connections though. The manuals for using Nighthawk routers in AP mode specifically say:
"Use an Ethernet cable to connect the Internet port of this router to a LAN port in the other router."
But we don't know what the model number is of this "Nighthawk".
As to the cable issue. That's why I suggested a "local test" to confirm that the configuration will work. Get it right with both boxes sitting in the same room, then move the other one to the end of the long cable.
