× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Connecting a 2nd router
PD69
can i hook up two orbi routers off the same modem. one will be placed away from the other about 14metres. i already have one router and 2 satellites. i have a spare router that i bought as it was cheaper to buy the 2nd satellite with it. any ideas?
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 6
Accepted Solutions
Guru
Re: Connecting a 2nd router
RBR routers can only work as a router or in AP mode. They can't work in extender mode like the RBS satellites.
Message 4 of 6
All Replies
joknutsen
Guide
What are you trying to achieve/ what do you want to happen?
I think the real question becomes if you ISP provider/modem will actually give you two IP addresses.
You might what to start by contact them .
Message 2 of 6
PD69
well i was hoping to use it like another satelitte.
Message 3 of 6
Guru
Message 4 of 6
PD69
thank you mate, that's all i needed to know
Message 5 of 6
Guru
Good Luck. Smiley Wink
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1973 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
