- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connection help
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm a novice! Connected the RBK50 but cannot seem to get the Add-on Satellite to connect. Any suggestions. Keep doing what the vids show and it just won't connect. I'm lost.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
How far appart is the satellite from the router? Should be starting at 30 feet.
Are you first pressing the sync button on the router, then press the sync button ON the satellite after you see the slow pulsating white LED on top?
Try factory reset the satellite. It will blink ON and OFF, then begin to pulsate slowly like it's breathing. When this happens, press the sync button on the router, then press the sync button ON the satellite. It should turn BLUE on top after a minute or 2. Give it 5 minutes if needed.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBE971 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connection help
Thank you and I will gladly give this a try.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connection help
Let us know how it goes...
