Orbi WiFi 7 RBE973
Reply
Connexion problem RBK23
Ragkzz
Hi !
I’m having an issue with my RBK23 mesh system, I am connected in Ethernet from my Satellite to my computer. Internet works on several programs like google and steam but I can’t connect to Uplay and Epic Games, they say I have a connexion issue. I have 404 Errors on several websites too but not on all websites.
My firmware version is V2.5.1.16. The base routeur is connected to my Proximus (Belgium) modem. Does anyone know how to solve this ?
Thanks
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 8
Accepted Solutions
Guru
Re: Connexion problem RBK23
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 6 of 8
All Replies
Guru
Does the PC work if it's wire connected behind the RBR?
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
Message 2 of 8
Ragkzz
Hey, I can’t wire the pc to the Router but I have the 404 error on certain websites also on my phone and pc. Actually Internet works on the computer but only on certain programs or internet pages. My Modem is the BBox3 from Proximus (Belgium)
Message 3 of 8
Guru
What mode is your modem working in? Router or Bridged?
Message 4 of 8
Ragkzz
As a router
Message 5 of 8
Guru
Couple of options,
Message 6 of 8
Ragkzz
Thanks for your help ! I am going to try this tomorrow
Message 7 of 8
Guru
Smiley Wink
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 753 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
