Orbi WiFi 7 RBE973
Reply
Constant spikes in latency / ping from ~50ms to ~2000ms every 30 seconds on wireless.
qxz
Follower
Follower
Recently, I have noticed an issue with Orbi that has been quite annoying. While on wireless, every 30 seconds ping spikes to 1000-2000ms. This is very annoying while gaming or on certain streaming services. For context, I have one satellite placed the recommend distance from the router and have tried testing ping without the satellite. The issue persists. I have tried with all of these settings on/off: Daisy Chain, MU-MIMO, Beamforming, 20/40mhz coexistence, andm changed Wi-Fi channels. Nothing seems to work.
Wi-Fi channels are currently set on manual at 6 (2.4) and 36 (5).
Firmware on V2.6.2.104
Any help is greatly appreciated. Thanks.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 3
Guru
Re: Constant spikes in latency / ping from ~50ms to ~2000ms every 30 seconds on wireless.
What devices do you have connected when your checking pings? Besure to test with out any wifi devices connected accept for the one testing device?
Do wired ping test show same results?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Message 2 of 3
CrimpOn
Guru
Can you give more information about this?  What was connected to the Orbi router?  How? (WiFi or ethernet?)
What was the ping target?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 960 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
