× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Correct Adaptor for Orbi AC2200 (RBR40)
Sunray20
Hi, I hope this is not too stupid a question but my adaptors have failed on two of my three orbi routers. I bought it in the U.S. and using in the UK so a voltage issue could be the reason but this has not happened on any other U.S. product I use. Is there a correct adpator I can buy in UK for this product? Thanks.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 4
Guru
Re: Correct Adaptor for Orbi AC2200 (RBR40)
Adatpers here for the RBR50 v1 I have is rated at 100-240v 50/60Hz Output to 12v.3.5Amp
These should work in your region.
Something to contact NG support and ask them if there is a more specific UK version of adapter that will work.
Message 2 of 4
Sunray20
Thanks!
Message 3 of 4
Guru
Good Luck. Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 547 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
