×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Correct FW
Retired_Member
Not applicable
Correct FW
Checking my FW, here's what I see.  I thought there was a newer FW ready for auto-update?
Model NameDevice NameCurrent VersionStatus
RouterRBR50RBR50V2.0.1.4No new firmware version available.
SatelliteRBS50RBS50V2.0.1.4No new firmware version available.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 4
Guru
Re: Correct FW
I would keep this on your scheduled review:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584/highlight/true#M26234
This seems to be the most current and up to date for Beta.
From what I know, theres nothing later than v2.1.3.4 which is most current Beta. Some saw auto updates come thru using this version only. We don't know if this was a fluke or what NG intended. Again, NG pulled the .v18 upate from the auto update services so that shouldn't be seen anymore.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 4
Retired_Member
Not applicable
Re: Correct FW
Thanks
Since I'm not experiencing any 'helmet fires' with my Orbi network, I'll just wait for the next available auto update.
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 3 of 4
Guru
Re: Correct FW
Old saying, "if it works, don't fix it."
Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 450 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
