× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Cox Cable Compatibility
Fpommett
I am looking to upgrade the router-modem for my Cox Cable "Ultimate" service.  Cox doesn't list the Orbi AC3000 as compatible with their service.  I think that's because it's too new.  Please offer advice.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 5
Accepted Solutions
Retired_Member
Not applicable
Re: Cox Cable Compatibility
@Fpommett wrote:
Thanks for your reply.  What model modem do you have with your Orbi router?
Frank
https://www.arris.com/surfboard/products/cable-modems/sb6183/
Message 5 of 5
All Replies
Guru
Reason why the RBK is not on there list or any list is that the RBK doesn't include a cable modem. It's just a router and wifi system.
Check there list again for what they support in "Cable Modem". NG has CM 1000, 1100 and 1200 modems that are just modesm only and will work with your RBK Orbi system.
Message 2 of 5
Retired_Member
Not applicable
I have cox and I recommend NOT using a router-modem combo.   I can't make out what you have now.
my cox system is  modem to orbi plus 2 sats.   That's it.
cox is one of the few isps that don't require you use their gear.   The orbi is not new.
keep it simple.
Message 3 of 5
Fpommett
Frank
Message 4 of 5
Retired_Member
Not applicable
Frank
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3204 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
