- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DDNS & Port Forwarding from within network doesn't work
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I have port forwarding of port 80 setup on my router to forward to a computer on my network. I've also setup DDNS to easily hit this webserver from outside of my network. I'm trying to host a basic web server as an experiment and ran into a bizarre issue.
When accessing the DDNS url or my public IP directly from within my Wi-Fi network, the page just spins and loads before timing out after a long while. If I get off my home network and hotspot my computer using my mobile hotspot I can connect to the DDNS url and public IP immediately.
Is there some setting that I'm missing in the NETGEAR admin that should allow this port to be accessed from within the network itself?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I've gotten my issue resolved. It seems I was running a previous firmware (3.2.16.6). I've updated to 3.2.16.22 (released mid-November). Now I can access my server from within the network by public IP, DDNS url, and private IP.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DDNS & Port Forwarding from within network doesn't work
The web page loads fine when addressed with the LAN IP address, correct?
It's just a guess, but the DDNS is resolving to the publici IP of the Orbi and it probably does not respond to connection attempts from inside the network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you mean by the private IP? My server is at 192.168.1.11:80 and I am unable to get that to load in a web browser. It just seems to timeout after about a minute.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jaron-lowe wrote:Do you mean by the private IP? My server is at 192.168.1.11:80 and I am unable to get that to load in a web browser. It just seems to timeout after about a minute.
Oh, my. A computer with IP 192.168.1.x cannot access a web server at 192.168.1.11:80?
Yet, it CAN be reached from the internet?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeah that's my whole issue. It's very bizarre and only forwards the traffic when on an external network. From within my network, It just spins and spins away. Seems to be only an issue with port 80 too. I've got port forwarding setup for RDP & Plex and both are having no issues internally or externally.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is this web server on a Windows machine? Windows Firewall has separate rules for "public" and "local" networks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is a Windows machine, yes. I've got the network set to private with network discovery turned on. Any setting you would recommend me setting?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jaron-lowe wrote:It is a Windows machine, yes. I've got the network set to private with network discovery turned on. Any setting you would recommend me setting?
Yes. On the Windows Firewall settings, "Allow an App or Feature through Windows Firewall", identify the web server software and check both boxes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Looks like both public and private are already on under those settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like loopback was fixed on v22...
